Calibre Biometrics Data
Hello
Is there a way to add recorded data from the Calibre mask as a chart for an activity?
The mask only connects to their application currently and they provide a summary of all recorded data (VO2, VCO2, RER, Fat burning…) as an Excel file.
I suspect that this feature may start bridging the gap for external data integration.
I’ve had this issue since 2020 with my metabolic cart. It only provides CSV from the platform.
I use Golden Cheetah (and WKO) as my primary platform and combine breath and lactate data for charting using XDATA. GC now will export FIT files with the imported data for uploading to other platforms.
Fitfilerepairtool will also allow you to add data into the FIT file. I’ve used this in the past with good results.
I do everything manually, but my workflow takes about 2-3 minutes to download the CSV, make a couple quick edits to format for Golden Cheetah and then combine data with the workout FIT data.
Check this post
