Adding my name to this wishlist. The more athletes I coach with Intervals.icu the more I want to show them comparisons with their previous workouts, for example their weekly Zwift race where we could compare and contrast, say, power curves with previous weeks. My theory is it’d be a useful exercise in viewing their mistakes, their improvements, and correlate that with results and goals.
Adding my voice to the choir. Comparing a select number of workouts to each other would be really helpful. I’d like to compare HR, power, and even lactate and breathing rate if it was possible to add those two metrics within workouts. Thanks!
I’ve been training #NVDP style (Nils van der Poel) where I hit repeat on the same sessions each week. Duration occasionally gets bumped for one or several of the sessions to build volume. It’s super interesting to track changes (mostly improvements) in power, pace, HR/Power, EF, etc, etc.What I’d like to have is the ability to see those metrics change over time such that each weekly session is added automatically to their associated chart. Creating custom charts on the Activity page doesn’t work since it’s only possible to limit scope by activity type. I want to group by things like: Monday’s “Long Run”, Wednesday’s “Long Swim”, Friday’s “Long Bike”, and so on.
I know David will produce a far slicker solution in the end. But until then you can do this in https://www.endura.fit
This article describes how to get data into the comparsion section (including linking to Interval), but in this case select similar activities rather than recent ones to compare. www.bluecattechnical.uk/Watts_my_CP.pdf
I would also like to be able to compare activities, FYI - Garmin connect web has a compare feature but I am sure intervals.icu can do better
You can get the same table view with Intervals.icu activities page in List view, but the ability to see power, speed or heart rate graphs would be cool to compare selected activities.
Here is a screenshot of a yearly run I try to do and what Garmin provides which may give some ideas. It does one cool thing where it shows where you are on the map for each activity you selected.
Here in Intervals.icu, you can see the stats in a table view using a search on the name, and then select whatever fields you are interested in to compare
This is a feature I’d be interested in if it’s not already possible. to be able to overlay graphs from same regular activities. So if I’m doing a 5km workout each week or the same event every year, to be able compare my performance and any progress or improvement in certain fields.
one of the functions I miss in intervals.icu. I am forced to use Golden Cheetah to be able to do this, but I find intervals.icu much more intuitive and less complex than GC
