Click “Options” and use the slider. If you set it to 1 then it becomes a linear scale.
This helps a bunch, thank you so much!
Hi David - Is there a way to display a different moving-average power (like 5m power, for example) as a chart, similar to how you are showing 30s Power there?
Yes. You can add a custom chart and add power to that with moving average aggregate. Then change the duration of the moving avg.
