I recently put on new cranks and realized when my post ride told me I increased my FTP by 28W (I wish!) yesterday, that I forgot to change the crank length in my Wahoo Elemnt Bolt v2 from 172.5 to 165. Is there a way to correct this in the .fit file so that it’s recorded correctly in my training data?
In Intervals you can edit the power with a fixed offset or a multiplier + offset. Activity page, Actions, Fix data.
In this case a multiplier derived from your actual FTP and the ´false´ new FTP, should be pretty accurate. Normal/Inflated.
Thanks. The crank arm is 4.55% shorter, so power should be overstated by that amount. So I will fix data by that amount. Much appreciated!
What type of power meter do you use? Only pedal based power needs correct crank length. For any other power meter it shouldn’t matter.
Yes, pedal-based power meter (Favero Assioma). I believe it’s just a 4.5% correction since 172.5mm is 4.5% longer than 165mm.
Now that I’ve fixed the over-reported power by scaling the power to 95.45%, I would like to export the fixed file and upload to Strava. Maybe I’m daft, but I don’t see where to down the file from intervals.icu. If this can be done – I’m surprised if it cannot – can somebody point me in the right direction?
Thanks so much!
Activity Interval Data page.
Fit File. Select both power and HR.
