Wrong Automatic Swim Intervals Detection
Hey
I manually record my swim lanes, but Intervals is having trouble determining and taking the break time into the session. In Strava an Garmin the Intervals a correctly detected
Is there a solution for this?
Data is sourced from Strava and the break times are recorded separately . (Screenshots attached)
PS: Program was 4x200m and 6x100m
Kind Regards Tobi
Can anyone reproduce the problem?
Could you please post an Intervals.icu link to that swim. Tx.
Here is the link: Intervals.icu
Tx. Intervals.icu is using the lap data from Strava and that isn’t matching the data traces very well. Could you try uploading a fit file from Garmin Connect and seeing how that goes?
Yes, I also think this is the problem.
My friend swam the same session and his data is from Garmin Connect. And the rounds are displayed correctly
Will this be fixed in the future, that this is working with Strava too?
Unfortunately not soon. Intervals.icu relies on the lap data for intervals in pace based activities so if Strava sends bad lap data it will fail. Files received from Garmin Connect also include lengths so everything can be worked out neatly. You best bet is to enable Garmin sync in /settings. There shouldn’t be duplicates even if you keep Strava enabled.
