Workouts on T-Rex 3 pro have only one interval
I just completed the first workout I created on intervals.icu for my t-rex 3 pro.
Following problems occured:
  • I planned 3 intervals (3*2k T-Pace with 90s rest); the T-Rex only did one interval;
  • the watch didn’t show the names I gave the workout steps. In my example “WU, T-Pace, Rest, CD”;
For the second one I am not sure if that is a bug, a limitation from amazfit (maybe you simply cannot name the steps) or if i did it wrong on intervals icu.
But with the numer of intervals I am sure it is a bug, because everythings shows up nicely in intervals.icu.
please share a screenshot of your planned workout
when you say, t-rex only did one interval, you mean only 1 interval got loaded up? intead of the expected 3?
for 2nd item, most likely a limitation. Believe Garmin has the same issue
Only one of the planned iteration are on the watch.
So on the watch is:
WU
12km T-Pace
1
90s Rest
CD
As you can see on the screenshot I have planned 3*2km(with 90s Rest). On zwift everything works fine but not on amazfit.
A quick update on this topic:
I tried another workout and in the following workout the 9 intervals are correctly implemented on the t-rex:
I am really not sure why one time it works and the other not.
Is there another t-rex 3 pro user who could also check this out?
Edit: in this case the power ceilings seem to be ignored. The t-rex only lists the duration (4min) of the interval and not the 305-320w part.
Further update: I could not replicate this error. I tried with a few other workouts and all have the correct number of repetitions.
Strange!
The workout where the error occured is still on the watch and has still incorrectly only one interval instead of three. hmm
How about deleting that specific workout and doing it again?
Maybe a glitch in the matrix.
I looked into this and Intervals.icu did send 3 reps to Zepp. If other workouts are working now then it may well be something they have just fixed. Please try re-creating or moving that workout to see if it fixes the issue.
I did modify it today (switched z4 pace to z1 pace) and dragged it to today in the calendar. The funny thing is: my watch still had only one repetition, but the pace was changed.
After that I changed the name of the workout and suddenly there appeared 3 repetitions as it was meant to be.
Weird.
But it seems to work well. Great work from you.
I hope amazfit will someday implement power as workout alert. Now you only have pace, heartrate and I think cadence for workout alerts.
As I love to use running power, I am somewhat disappointed that amazfit currently doesn’t support that.
A post was merged into an existing topic: Amazfit (Zepp) support available
