Workouts not being scheduled on Garmin watch
Previously when I created workouts for my athletes, I would create them in a plan, push the plan to the athlete and on the day, Garmin would then suggest to run that workout - if the athlete would select to run that day.
Now, the only way for the athlete to run that planned workout, is to manually find it and select it.
The workouts themselves are showing in intervals.icu on the right date, they are showing on the Garmin Connect calendar, the watches are just not picking it up.
Does this have to do with how I set my workouts up? Or has something changed in the sync between Garmin and Intervals.icu?
Sorry, but if it’s in GC, then why should it this an intervals bug?
Did you change anything on your workout description?
Did you raise a bug report at Garmin?
I think I found out what the issue is, just need to test it when the next workout comes up.
My adding a note at the end of the workout in intervals with a - in front of the note, Garmin is marking the whole workout as other… Which won’t be picked up when the athlete selects a run.
Solution is simple: add strength as a separate workout in the schedule. Not as a note.
