Are you able to mix and match HR, Pace and Power in between different aspects of the workout. e.g. for running
warmup
- 45m Z1 HR
workout 5x
1m Interval Z5 Pace
30m Z1 HR
warmup
workout 5x
1m Interval Z5 Pace
30m Z1 HR
Hi, I also used ChatGPT to get a consolidated guide to intervals.icu workout builders syntax and rules. Should help anyone trying to understand what is going on without having to search over the entire topic in the forum.
Basic Syntax
Example Workout
plaintext
Copy code
3x
4m @ 100% 85 rpm
2m @ 50% 90 rpm
No. Each step can have different types of targets (power/hr/pace) but the athlete needs to choose one way to do the workout i.e. all power, all pace or all hr.
Solved!
When I planned a running workout with Garmin, the watch showed me the time of the last interval for a few seconds after an interval. So I could see at a glance how fast I was at distance-based intervals. Is that also possible here?
It works with the text “intensity=active”. Now I get the elapsing time displayed after the interval.
I have the following problem. This is my Workout:
Warmup
- Press lap 2km intensity=warmup
Main set 10x
- Run 400 meters intensity=active
- Recovery 200 meters intensity=rest
Cooldown
- Press lap 2km intensity=cooldown
My questions
Intervals.icu creates the work intervals and the gaps between them are “recovery”. So likely there is a rounding issue between the laps when you get a 1s recovery interval.
I have added support for setting lap intensity from the workout step messages in the fit file when intensity is not already set on the laps (your case). I will deploy that on Tuesday AM. Then if you do Actions → Reprocess file you will get “intensity = rest” = Recovery.
This is exactly what I would like to have
Hello All,
Have you ever set up a Swim workout?
Do you have any samples?
I mean, they should be based more on distance than HR…
Thank you in advance
Thank you - I try it this way .
Thank you. Now it works. “intensity = warmup, active, cooldown” is assigned to work. “intensity = rest” ends up in recovery.
If I’m not mistaken, 1’30 will be correctly interpreted by the workout builder as 1’30s, even if I don’t write (or forget) the “s” (for seconds).
But the same doesn’t happen with 1h30, where the minutes will not be recognized. We have to write 1h30’.
once you’re used to using the the full format, it’ll be a breeze
-1h30m2s Z2
-1h0m5s Z2
