If you add a step like β-5m z7β wb counts z7 as a 151-999% resulting with very high load counts (i think it takes around 570%, probably just a middle point of the % range /151+(999-151)/2/). In a perfect world z7 should take top limit from power max for this season or smth similar. Or if it is to complicated to implement maybe just stick with much lower top limit, 700% or so making middle around 400%.
Unfortunately itβs quite dangerous for me to change that because the same code decides what ends up in file formats that do not support ramps. Example: An MRC file would get a very different percentage for Z7. The workaround is just to use a percentage or percentage range instead of Z7.
Itβs ok.
It is a small bug just wanted to point out that if anyone uses z7 it counts load higher (on a positive note the intervals at z7 are very short anyway so the diff is at the end not that huge).
Yeah I figured out i can simply just put 1000w or something similar. Just spotted the bug bc it gives me an interval of 496-3296w and it looked a lil bit crazy and depressing at the same time
