Wellness data (sleep) only syncs from Zepp after manual web login
Hi everyone,
I’m having an issue with wellness data synchronization (specifically sleep data) from Zepp/Amazfit via API.
The Problem:
My workout data syncs perfectly fine, but wellness/sleep data does not appear when I fetch it via the API (GET /athlete/{id}/wellness) unless I first manually log into the Intervals.icu website and open the Calendar page. It seems like opening the web interface triggers the sync, but calling the API does not.
My Setup:
• I am using n8n for automation.
• I’m calling the endpoint: https://intervals.icu/api/v1/athlete/{id}/wellness?oldest=YYYY-MM-DD&newest=YYYY-MM-DD
• I have tried to “wake up” the sync by calling GET /athlete/{id}/events before fetching wellness data, but it doesn’t seem to trigger the Zepp import.
Question:
Is there a specific API endpoint or a parameter I can use to force a sync/refresh from external services (Zepp) before I fetch the wellness data? I want to automate this process without having to manually open the browser every morning.
Thanks in advance for any help!
I’m having the exact same issue.
Same problem, did you find any solution?
This is intentional behaviour.
Ahh that’s a bit disappointing :sweat_smile:
Do you know if there’s any way to trigger the sync programmatically?
For example, simulating a login via HTTP request (maybe using something like n8n)?
Ideally without relying on cookies/session reuse, since those expire and I’m trying to build a fully automated pipeline into Google Sheets.
You probably can use curl to simulate a web page visit. I have no idea what capabilities Google sheets has.
But you need a cookie, though I think intervals cookies don’t expire.
I have asked Zepp about their webhook plans.
Thanks! I’ll give it a try :+1:
That’s awesome, really appreciate you checking that out! :raising_hands:
Would be amazing if they actually add webhook support
The Zepp team got back to me. The plan to add webhooks for some wellness data (e.g. sleep) in the “next few months”.
Thanks a lot for the update, really appreciate you checking this out.
