It would be very helpfull to have the daily wellness data on the overview page (the page where we see all the coached athletes listed with their fitness chart).
Yes that would be good. I want to revamp that page and make it work like the activity list view i.e. let you choose which columns to display for the athletes.
@david
Would it be possible, please, to add a tick box to show/hide the wellness data on the activities page?
Currently, as far as I can see, itās only possible to select what to show.
This tick box would simply show/hide the slected fields, which isnāt possible currently using the normal/compact/minimal layouts.
Trying to find a suitable topic already raised, instead of starting a new one.
You probably mean on the āCalendarā?
The list of wellness parameters in this dialog has 2 outcomes:
- It lists what is visible on the calendar
- and it lists what is exported in the csv
So if you regularly use the csv export and export things that you prefer to not be visible on the calendar, itās a bit of a pain⦠Itās easier to use the API to get specific things.
Anything in the list is displayed in all three different views Normal/Compact/Minimal.
To avoid any confusion, but you most likely know that:
This list does not influence what is visible on the Wellness dialog where you enter daily parameters. That dialog has itās own parameter configuration.
Yes, the calendar, but itās called Activities hence the reference to the āActivitiesā page.
The reason to show/hide the data is to be able to see more of the calendar on one page/screen without having to scroll up/down. To hide it currently, means having to remove the list that is, or used, for the export and then add it again.
Edit: asking to show/hide from the screen to capture daily values is only for the day, and might not allow hiding all.
Ha, yes. I was confused because you were talking about Activity page in singular⦠which would then be an opened activity.
Iāll amend it to show Activties page⦠just to be clear.
