Weight Training and Stretching
I want to be more consistent with resistance training twice a week and would welcome recommendations on a regimen that supports a cycling plan but also is designed for overall health and longevity as we age. Back in my youth, weightlifting was part of my daily routine with competitive sports, but I’ve done very little since taking up cycling 10 years ago. I’ve tried these recommendation from TR, but haven’t been very compliant (and spiderman pushups are hard! :cold_sweat:) Strength Training for Cyclists: 10 Exercises for Cycling Weight Training - TrainerRoad Blog
Post-ride stretching is another thing I don’t do regularly. I’ve started going to a stretch studio weekly for a 30-minute trainer-assisted session after a VO2 Max workout to see if that makes a noticeable difference. https://www.stretchzone.com/ I’ve done two weekly sessions so far but don’t have an opinion yet if this is adding value to my fitness.
Will you be using weights/going to a gym?
I go to a gym with free weights and machines twice a week, but also do some planks and other body weight exercises at home.
This is a truly murky topic, @David_Williams.
The # 1 lesson that everyone emphasises is technique. So a gym is good, especially if you can get someone to comment on your technique. If not, you have to find apps that have videos.
So the strength training programs fall into two categories – [1] those that aim to make your legs turn around faster with more power and [2] those that empower your body more generally with the result that you become a stronger / more comfortable cyclist. I do the latter type of exercise with a strong focus on core, generally at home, with lots of videos; and with videoing myself. Of course, that does include some leg exercises, such as squats.
In that latter category, there is a variety of apps / websites. Eg: https://new.dynamiccyclist.com/ and Human vortex training [see the introduction to his programs here: The 3 Day Strength Training Plan for Cyclists Over 50 - PezCycling News].
Those are two that I know of; there are no doubt more.
I am certainly no weight training expert, but I did spend time researching the subject late last year as I was particularly wanting to do weights as part of my training this year.
From a cycling/ racing performance point of view, the consensus seems to be that you need to be doing heavy lifts for the legs, so squats, deadlifts, step ups, leg press, leg curls etc. of course to a lesser degree the upper body needs some work but not the heavy lifts and of course some core work.
I started by reading the weights section in The Cyclists Training Bible by Joe Friel, Weight Training for Cyclists and by reading material and videos on the internet.
You may know all this already of course but the way I programmed my lifting was to divide it into 4 phases
Anatomical Adaptation
Transition
Heavy Lifts
Maintenance
The AA concentrated on getting the body used to lifting, so start with a weight that you can complete 20+ reps on and maybe 2-3 sets of each. The AA phase lasted about 3 weeks and you slowly add weight but maintain the high reps. Then legs moved on to the next phase but upper body remains in AA.
Transition is where you start to increase weight towards the heavy lift and target perhaps 10-15 reps with 3 sets of each slowly increasing weight each session in the gym. The transition phase should last about 2 weeks.
Heavy Lift should target 3-10 reps, once you can do 10 on the first set then increase weight.The heavy lift phase should last about 3 weeks
There is another phase you can do after the heavy lifts that I forget the name of but it is where you go for explosive power so focus on fast reps on the legs.
Maintenance
As you get into the build phase you will want to drop the lifting to specialise HIIT on the bike but a once a week maintenance lift is often recommeded with lighter weights.
2 or 3 times a week is suggested, I started out going to the gym 3 times but this ended too much so I reduced to twice a week.
Lifting should replace High Intensity work on the bike.
Here is what exercises I was doing. I stopped going when Omicron arrived as the gym seemed like ideal breeding grounds. By the time I was willing to go back I considered it too late to start again as I was focused more on the bike. Maybe I will start again this November.
Squats
Lat pulldowns
Leg Press
Heel Raise
Single arm row
Dumbell shrug
Leg Curl
Seated Row
Bench Press
Abdominal twist
Abdonimals straight
As far as stretching is concerned I do tend to neglect this a bit but try to do just 4 simple stretches
Calf, Quads, Hamstring and Glutes
