Weight settings reverts to previous
When I go to settings I originally input my weight as 180lbs. I do usually hover around that weight, so it hasn’t been a big deal. However, when I do lose a couple pounds, I try and manually set the new weight in settings. It does it initially and all adjustments are made in eFTP, etc. However, as soon as I come back, it has reverted to 180 lbs. Am I missing something?
I suggest you make ongoing changes to you weight via by changing it on the activity page using the wellness data tab. This will then update the settings page value shown and should keep your weight at the correct value.
I had a look at your settings and you have “Update weight from Strava” ticked in the Strava box. You need to untick that.
That was it. Thanks so much.
