Watts & Weights — a hybrid strength/cardio app built on top of Intervals.icu
Hi all,
I’ve been building a training app (with AI) for the hybrid-athlete niche (lift + ride/run) and would value feedback from this community. Intervals.icu sits at the heart of the integration and you’ll spot the rough edges faster than anyone else.
What it does
Watts & Weights is an app for strength training that treats Intervals.icu as its ground truth for anything cardio + wellness. The one thing I couldn’t find in any other strength app: the planner sees both sides of your week at once. When it prescribes cardio it knows what you’re lifting tomorrow; when it prescribes lifts it can see your stats from ICU. That coordination is the whole reason this exists.
Where Intervals.icu shows up
  • Reads — 21 days of wellness (HRV, RHR, sleep, CTL/ATL/TSB, cycle if set), 21 days of activities per sport with power/HR summaries, per-sport thresholds (FTP, indoor FTP, W′, LTHR, run threshold pace), and any scheduled events. All of it feeds the AI context so suggestions cite your actual numbers, not vague “based on your history” hand-waving.
  • Writes strength sessions — completed lifts upload as WeightTraining activities with icu_training_load (Foster-derived or TRIMP if HR-strap), kg_lifted, icu_rpe, feel, average_heartrate, and TCX HR stream. Load formula falls back to a √(kg_lifted) × 1.2 baseline when RPE/HR are missing, so tonnage sessions don’t upload as 0.
  • Writes structured cross-training — AI-generated Z2 / interval / mobility sessions push to the calendar as real structured workouts using ICU’s step-text description syntax (- 8m 88% warmup, 4x blocks with %FTP/%LTHR targets, cooldown). ICU parses them into a workout chart the head unit or trainer can execute, not just a calendar note.
  • Recovery import from ICU — a “pull my strength history back from ICU” flow that reparses the descriptions we uploaded and re-hydrates local workouts (HR streams included, muscle-group tagged from the local library by exercise name). Built after I switched Google accounts on my phone and lost several months of lifting history I hadn’t backed up.
What the AI actually does
Four capabilities, all grounded in your ICU numbers:
  • Training readiness — subjective self-report + HRV/RHR trend + TSB → verdict (go / modify / rest) with muscle groups to focus/avoid.
  • Long-term — 21-day rollup + strength benchmarks + goal → focus areas plus a cardio prescription (weekly hours, intensity split, key session types anchored to your FTP or LTHR).
  • Today’s workout — generates a strength session tuned to readiness + goal + equipment.
  • Cross-training — generates 1-4 weeks of non-strength sessions that avoid stacking hard cardio on heavy lift days. This is the one that surprised me most in daily use.
Honest limits (before you try it)
  • BYOK Anthropic key required for AI features. No hosted-key option yet. Non-AI workout logging works fine without one.
  • Android Chrome or desktop Chrome for HR-strap Bluetooth. iOS Safari has no Web Bluetooth — live HR features don’t work there. Everything else works on iOS; the strap has to sit on your Garmin/Wahoo instead.
  • PWA only, no App/Play Store. Add to Home Screen from the browser.
  • Alpha-ish. I use it daily but it isn’t a polished commercial product yet; expect rough edges. Issues and PRs welcome.
Link: https://fittrack2-ruby.vercel.app​
I’d especially value feedback on three things:
  1. Whether the description-text workout_doc approach for structured workouts renders correctly on your side (I’ve tested against my Elite Suito setup but ICU’s builder syntax has corners).
  2. Whether the “strength-load-around-cardio” scheduling is producing plans that feel right when you use them for a couple of weeks.
  3. Anything obvious I’m missing in the ICU API that would let me do this better — I’ve mostly stuck to /wellness, /activities, /sport-settings, /events and the standard POST /events for pushing.
Not going to pretend this replaces TrainerRoad/Zwift for pure endurance work. It’s for people who lift AND ride/run and want them coordinated — which is a smaller niche but one nobody else seems to be serving well.
Obviously, this is built with AI and would value any feedback if you find this type of app usefull.
Cheers, Peter.
Hello everyone, I deployed to wattsandsquats.com, which seems like a nice domain and app name.
Couple improvements since last time
icu integration
  • each set is now an interval on the activity. “Bench Press · set 2 · 80 kg × 8”, with rest segments in between, so the intervals table shows hr, duration and load per set
  • garmin mode. if you record strength on your watch, the app doesn’t upload a duplicate anymore. it finds the garmin activity once it syncs and adds rpe, feel, kg lifted, the set log and the per-set intervals to it. icu’s own hr-based load stays untouched
  • uploads now use the real start time and your local date (late sessions used to land on the wrong day)
  • finishing a strength session no longer deletes a planned ride/run on the same day, and the app stopped overwriting your own wellness fatigue entry
training side
  • supersets, both ai-generated and manual. the app alternates the two exercises automatically, with a short transition between them and a shorter rest between rounds
  • rest pace setting (quick / standard / long)
  • extra weight on bodyweight exercises (weighted pull-ups etc.)
  • 3-question onboarding that builds a 4-week plan from 10 hybrid templates
hr strap
  • remembers your BLE strap and reconnects it when a workout starts, and again if it drops mid-session
  • HR and the workout timer survive a reload or android killing the tab
still required you bring your own claude key for the AI bits, still no account needed, you can try it localy.
I dont want any money from anybody, if your Hevy or Strong do not work well for you, try this :slight_smile:
This is cool, and almost what I am trying to build. Will give it a try.
Thanks for putting this together! I’ve been using it for a few weeks and really like it. I’ve mostly been using it as a workout logger that shares with intervals.icu and haven’t been using much of the AI generated workouts and such, but still find it valuable.
Some questions/observations. When I load up a premade workout or an AI generated workout, there is a superset button to add an additional lift to work in, but that button doesn’t show up when trying to make a new workout from the “New workout”->“Create your own” button, can that be added in? When adding an exercise, it also doesn’t add in a warmup set like it does in the premade workouts, is that true or is the first set just the warmup set?
Is my observation correct for overloads, that it takes the weight from your first non-warmup set and then the reps from your lowest rep set, and applies overloads to that? It seems when I do a pyramid type weight increase, or if I do multiple warmup sets (making the 2nd warmup set the 1st working set), then the overload will apply to low weight and low reps, even if I did some sets way above that. For example, if I do squat, warmup 135x10, then 155x8, 185x8, 205x5, then 225x3, the overload it applied afterwards was 155x4. It seems that it’s saying 155lbs was my first non-warmup weight, so it’s probably expecting me to do multiple sets at that weight, then my lowest rep was 3, so the overload applies a 155x4, despite being able to complete lifts heavier than that. I do plan to move to either a 3x8 or 5x5 at the same weight plan, just want to understand how it works. If I do multiple warmups, how do I add multiple warmup sets?
