The Wahoo activities its not uploaded anymore to intervals.icu. I deactiveted Wahoo sync & reactivated again, but no success. If i download .fit activity from Wahoo and upload to intervals.icu, the activity doesnt show on inetrvals.icu.
Yes, that ways its showing. But, i dont deleted it. Same with syncs from Zepp & Garmin Connect. They shows as deleted, but i dont deleted them. Very strange.
- You can bulk undelete from the Activity List view. Just FYI if you have a lot to undelete
- You should check all your sources. Normally only Strava activities will be deleted in favour of direct connections. Seems strange that your direct source activities were deleted, unless you somehow unintentionally made a mistake.
I observed this problem since i sync data from my Huawei watch via the Health Sync app. Since then my other apps (Garmin Connect, Wahoo, Zepp) won’t sync (or sync as “deleted” activities).
Anyway, thanks for the help!
You probably should only sync from Health Sync the activities that you can’t get from direct connections. That is, if Health Sync has that functionality.
That’s what i did. I use Health Sync only for my Huawei GT6Pro, because intervals.icu doesn’t support it.
Activities from Garmin, Amazfit and the chest strap should sync directly through their apps to intervals.icu, but for some reason they appear as “deleted”.
