I was just wondering if you collect the VO2Max metric from Garmin at all? I wanted to make a custom chart tracking that over time. It would be super cool if you did and if you already do, I am lost as to where to find it.
Intervals only gets the original FIT file from Garmin and performs all calculations based on that input. Parameters from the Garmin Connect webpage are not accessible. VO2max is a metric that became available with the Firstbeat algorithm. Firstbeat was aquired by Garmin recently.
Didnāt know that it was in the fit file. Always tought it was calculated on Garmin Connect and not on the device. Sorry for the mis-information.
Now before paying too much attention to it, read these articles first:
Not sure its in every FIT file to be fair. Iāve done a bit of digging into files generated by my Garmin FR735 and canāt find it. Height, weight, FTP and other data is there. I see the Garmin post talks about an FR945 so maybe only in files generated by the later models? Happy to have a dig if someone want to provide a sample file from a 945.
I think I know how it goes:
The Firstbeat algorithm runs on the unit and not on Garmin Connect as I tought before. Thatās pretty sure because I remember now that a new VO2max is detected right away on the unit. The message from @PASFOU made me think this over.
In that case, the VO2max value would only be present in the fit file from an activity where a new VO2max is detected and passed to Garmin Connect in that way.
Unfortunately I canāt check that because I disabled the notifications after reading above articles. There is not much sense in tracking a value that is not correct, but thatās just my opinion.
VO2max history is probably kept on Garmin Connect, and as far as I know not available for third party software.
If anyone has a fit file from an activity where a new value was detected, this could be checked for validity.
I just had a look at my most recent ride (Garmin Edge 130+ with Polar H10) and no VO2max in the file. But my riding is in a bit of a dip so not going to be setting any new records right now.
I do have a todo list item to calculate this. I did find some good references.
I have the same setup. My garmin connect VO2m seems to show updates on activities that are either long or involved more intense intervals. Dots show up on the graph even when values hold steady, but only if the ride is long/hard enough. I havenāt looked in at the files themselves
One of the VO2max mentions within that is as follows:
# Not part of the official ANT SDK doc
message 79, 'user_data'
field 0, 'uint16', 'metmax', :scale => 1024, :unit => 'MET' # VO2max / 3.5
Iāve loaded a number of activities into www.fitfileviewer.com, and by deactivating the filter āHide messages without name (āmesg_num #ā)ā, you can find your Garmin determined VO2max:
A bit of maths later (x3.5/1024) reveals the VO2max value of 53.7 ml/kg/min.
Of note, I think this is your pre-activity VO2max value from Garmin Connect rather than the updated one from the activity in question, based on the values seen in a number of my FIT files.
I donāt want to spoil all you guys enthusiasm and I totally get that there may be some people getting some motivation out of this value and therefore do want to see it also in intervals.icu. So having it as a non mandatory and most importantly, opt-in field (added with the respective caveat notes) is something no one could have anything against.
A valid training metric in the case of the Garmin / firstbeat implementation, it is not. And shouldnāt treated as or mistaken for and especially not mixed with VO2max values as a result from metabolic tests.
In trying to help someone else, I stumbled across the VO2max value that originates from the HRV4Training import csv file. Iāve unticked that box, and left the Garmin Connect tick box as ticked. Will see what happens tomorrow, as HRV4Training is updated in the morning, and all my Garmin values (fit file) would be uploaded after.
i v seldom use HRV4Training nowdays, but also helping the same person as you , i saw that I didnāt enable VO2Max import from dropbox for it anyhow (since day1 i guess)
The Vo2Max on my wellness is updated. Tho I am unsure if the data that I can plot in the Fitness Charts is using VO2 from the FIT file or from wellnessā¦
