Vlamax high training
For arguments sake i got a power profiling test done and it came back with a high vlamax but needs to be lower. i have high vo2 but the ability to sustain short term efforts like 5-10secs 20-30secs is low and get big watt numbers. threshold is 305w but ftp is 360w. geared more towards triathlon sprint ,Olympic. any suggestions or any sites to check into? for cycling programs rather then your traditional more endurance etc. do i need cp etc…
@Keith_Dwane What is your measured VLamax? If it was more than 0.4, then it’s pretty straightforward. You need to NOT do anything that raises VLamax such as high intensity training, although we should always do ‘some’ periodized HIIT. Best bang for your buck is tempo/SS work performed with low cadence/high torque (example, take your neutral cadence minus 10 rpm, goal could be 60-70 rpm for this work). Nutrition plays a big role also. I don’t recommend ‘fasted’ rides, but morning rides before breakfast (when our glycogen stores are low) go a long way. Also, sticking to a consistent schedule is important in lowering VLamax. With a reduced VLamax, you’ll be able to drive your FTP up.
