I figured the issue, it was something do to with my NextDNS’s filtering system for ads and tracking. I added it to the allowlist.
Cool app Evan - thanks! I noticed a problem. The summary of my weekly activity is incorrect. See attached screenshots from Veloq v Intervals.
Also, I often do workouts in an app that only uploads to Strava (not intervals) so it doesn’t get captured in Veloq. Is their a way I can get it into Veloq?
Thanks mate! And good find! The difference here is that the app uses a seven day rolling window rather than the actual week for that stat, but your observations are right, it should align better with intervals.
A change for that will be out in the next version, along with some other fixes that have been brought up here (thanks all!) - but it might take a week or so. I’m hitting a wall with several issues in the map library at the moment.
Regarding your point about the workouts coming from another app, unfortunately, no, I don’t have any immediate plans to integrate anything other than intervals. Are you unable to sync these from Strava to Intervals?
Sounds good, thanks for the reply.
And yes, those workouts and all their data sync to intervals (via Strava).
FYI the same issue exists with Sub Intervals app. It see that their was something uploaded to intervals but doesn’t have any of the data.
Ah! Yeh, I think this has something to do with the terms of use of the Strava API. David talks about it here: Import all data from Strava
and some more detail: [SOLVED] Data misssing through API (Strava Restrictions)
Unless you import those directly into Intervals, I don’t think they will be available in any app using its API.
Got it. So I’d need to download and import into intervals a fit file or something similar.
Hey all, it’s been a couple of weeks, but I’ve been busy working through a lot of the feedback from this thread - really appreciate all the testing and suggestions you’ve been providing.
I’ve just pushed version 0.1.1 to the App and Play Stores internal testing so give it a go if you get a moment, it may take some time to become available from the time of posting here. This one has some big changes, especially in the backend, expect some hiccups – it’s quite hard still at this stage to keep everything tested on both platforms as a single person :')
With this release, unfortunately, you will need to clear your sections and rebuild them for everything to work properly if it doesn’t happen automatically, and if the custom sections are still giving you trouble after that, a reinstall should sort it out. Sorry for the hassle, but it was necessary for the refactor. I promise to keep that more stable in further releases.
Some things you’ll notice based on your feedback:
- New menu-based UI - @R2Tom you asked about bottom navigation, so I’ve switched completely to many navigation. It meant some consolidation in some of the pages, let me know what you think
- Imperial/metric units - @Alpaka we now have imperial units, this can be changed in the menu, and the default one used will obtain whichever units are set in your intervals.icu profile.
- Chart improvements - Y-axis labels and average line with tooltips, so you can actually see the values now. If you want to see the y axis on any other overlaying plot you can hold the chip to see them. Also for a quick view of other plots you can hold their chip button to quickly see the data overlaid.
- @Alpaka with your suggestion we now have PRs uniquely for routes/sections
- Custom section fixes - @Manuel_Oberti the renaming issues should be resolved hopefully
- Much faster initial sync with the new background download engine
- Reorganised fitness tab with power/pace curves and training zones
- Satellite/aerial basemap options
- A bunch of stability fixes, but with some potential for some issues in iOS still (having a feature parity hamonised approach for both platforms has not been so easy!!)
Performance is my next focus - so if any page feels sluggish or janky, please let me know which screen, what you were doing, and roughly how many activities you have.
I’m looking forward to getting this out of testing and into a stable release soon. Thanks again for all the help getting it there!
Hello all!
The bugs have been ironed out, and the app has now been released on the stores ![]()
Google Play - Veloq
App Store - Veloq
If you are not able to afford the store price, you may sideload it for free using your preferred method. The release for each version on both platforms can be found in the GitHub releases. Of course, don’t forget to support intervals.icu if you can too !!
For those who helped out by testing and sending in crash reports, thank you. Please get in contact with me with the platform you use, and I will send you a coupon to download for free.
And as always, if you have any feature suggestions or bug reports, feel free to add them here in this thread or in Veloq: Issues on GitHub.
Hi @evanjt, thanks for all your work! App looks great now.
Love the map overview with heatmaps, too. Is it possible to have the heatmap visible on higher zoom levels too?
Yes, I would love to add this, too. In fact, heatmaps were included at an earlier version, but I removed them completely after having a terrible time stabilising the global map. Thanks for your support and feature requests !
Hello all ![]()
A new version (0.2.2) will be released on the stores soon, with some significant visual changes. We now have 3D map previews on the activity screen, and the dark map vector layers have been improved so we can see the roads better than before.
3D previews can be generated on all routes in “smart” mode where only those with significant elevation changes are considered worthy to preview. The rules for each map can be set for each activity type, or they can be changed individually by holding on the activity itself. Additionally, if you are changing the map inside the activity detail page, the last map type or 3D mode will be saved for when you go back to the activity feed.
A lot of internal changes to improve the general speed of the app, the retrieval of data, including local tile caching and faster parsing of route/section data, and there have been some improvements sitting in testing for a while, such as PRs for both directions in the section detail screens, fixes to edits of sections and other cosmetic changes.
In this release, we now have activity intervals that are not shown by default and nested underneath the activity plot. Opening it will draw them on the plot and show you the information for each set.
and if you look carefully in the activity feed, a new horizontal bar will show a preview of these intervals too.
There are still quite a few features I have in mind in the pipeline, half completed, but they require a bit more testing. And of course, if you come across any bugs or have feature requests, you may post them here or in Github and I’ll try my best to get around to them for you ![]()
Cheers!
Hey all !
Today I released 0.3.7 onto both stores. Quite a few changes in here since the last 0.2.2 release. I have put both for free until the end of next week – allowing everyone to use the app, and for those using the sideloaded version, a good opportunity to get the signed version
. Overall, besides some significant performance improvements:
The Routes tab has become an Insights tab, including now a page that finds some patterns in your recent activities, such as progression in sections and routes, new recent PRs, volume insights on strength workouts (more below). On each page, you will be able to see why it’s an insight, and interrogate the activities related to it.
Routes and sections are now grouped by their sport, and you can switch between them in the detailed view of each. Here you can see that the plot has changed to a scatterplot over the entire time period. You can delete assigned activities from each by selecting their point and pressing the x icon, or adding them by going into an activity and clicking the search for more activities (it will look for the nearest ones). Pinning (accepting) an activity means that it will not be modified at all by the app, for example, if you choose to reanalyse your sections, or the matching algorithm changes in the future. This is by default if you create a custom section.
Editing the bounds lets you trim (or expand, which uses the activity trace of the reference activity – you can change this by choosing the point on the plot and pressing the star icon to switch the reference activity) if you disagree with the match.
Strength workouts now show muscle groups and exercises if the data is available. This is still beta and has only been lightly tested with Garmin. On a strength activity load, the .fit file will be processed in the app, and aligned to muscle groups according to the exercise mapping in the free-exercise-db library. With this feature, we track pairs of muscle groups for insights, and we also show the full body preview in the activity view. A note on this: Garmin (for me at least) does not always select the right exercise, and by the time I make edits to the exercises in the Garmin app, intervals.icu has already picked up the exercise data, so the edits in Garmin do not propagate to Veloq. I welcome any feedback on this, and I plan to allow remapping an exercise to muscle group changes in the future.
Section generation has some new methods to generate with, which can now be customised. The app has moved its default to find corridors in the activities, which is more likely to pick up parts of your activities that have a higher traversal in common places, rather than simply finding matches. You can play around with it in the Section detection panel in the settings page.
This library sits at tracematch and now has bindings to WASM and Python. There is also a demo page at match.veloq.fit where you can put in your own .gpx files and play around with the matching algorithm.
Push notifications are now opt-in. When you do a new activity, you will be notified of its update in Veloq. This is an opt-in feature. Doing so will push your athlete ID to our server to manage push notifications, which will be removed if you disable notifications in-app or auto-expire in 30 days if you stop using them. Instead of showing in an in-app banner, these notifications will also include information about app behaviours, such as download activities, heatmaps, routes, and sections.
Heatmaps are now generated on the device after initial sync, and progressively updated as more activities arrive. This lets you see all your activities on the global map. We have also enabled clustering in the global map to see the cluster groups at wider zooms
Thanks again to everyone testing, posting feedback, and putting up with my early bugs. Both apps are free on the stores until 24.05.2026 (Android starts tomorrow); a good window to share with friends who might find it useful. If it’s earned a spot on your phone, a store review, a tip from the support section in settings, or a comment here or on github, will help keep the project moving.
Looking very nice, will test the app,
Some things I already notice.
- Cycling FTP say’s 400 (I wish) should be 270, wher does de 400 come from?
- On the tab Health you’ve got Season comparison; It would be more logical to first show the bar from the previous season and then the bar from this season. reading left to right
- map browsing is a bit slow and seem to crash sometimes.
- editing sections is difficult for the section trim is over the map, and also to crashes sometimes.
- openwater swimming graph pace is in min/km instead of min/100m
- Overall: looking good.
Thanks! You have great eyes ![]()
Unfortunately, I mostly run, so I have zero swimming records and only a few cycling activities to test with my own data, so this is invaluable. The FTP was most definitely set incorrectly, I apologise for embellishing your records
, I’ve also been sure to distinguish more clearly between FTP (in the profile) and eFTP, and the swimming units have been fixed, too.
I’ve applied your feedback and made changes to the season comparison and section editing, with more screen real estate for editing and a remodelled scrubbing experience (to move the start and end points at different speeds, like iOS scrubbing).
With the map view crashing – that really sucks. This is always a bit trickier, but I imagine you have a lot more data than I’m working with, so I’ve added some more logic to avoid crashes and am going to try testing with more synthetic data.
The changes are with the stores, so you’ll see them come in as updates during the next day or so ![]()
