Is there a way to ignore a jump from 0 to a value directly in the script? Fixing that for every activity is too laborious
Cropping the first couple of seconds is the only other way that I know of.
Select entire activity except first 10-15 sec, then Actions - Crop. Easiest to spot what you need to crop is the Elevation chart.
Solved: You can fix that error by adding the following lines right after “let altitude = stream.altitude;”
let startIdx = 0;
while (startIdx < altitude.length && altitude[startIdx] <= 1) {
startIdx++;
if (startIdx > 0) {
altitude = altitude.slice(startIdx);
This way, the data processing will start from the first altitude value greater than 1, avoiding issues caused by initial zero.
I’d like to test that but I can’t find “vam peak” anywhere… where do I have to look for ?
Thanks !
awesome, thanks !
I forgot about Activity Charts and was looking at Charts…
