Maybe there’s already a post about this, I couldn’t find it.
I got a road bike with favero pedal powermeter and want to buy a mountainbike where I’ll use another powermeter. I’m sure some of you already use multiple powermeters on different bikes. How do you cope with the data noise generated by differences between the powermeters?
Not quite the answer you’re after, but I swap my faveros over three various bikes (takes less than a minute - see GPLama’s ‘how to change pedals’ video): saves money and maintains consistency.
I have an outstanding todo item to add gear with an option to adjust FTP based on the bike used (e.g. 95% on TT bike). This will fix load. Could also scale power but might be better to leave as is and then you filter power curves for road or MTB or gear used etc.
I have a Quarq DZero crankset on my road bike, and a 4iii left crankarm on my gravel bike. The Quarq is extremely close to the numbers from my Kickr (within 2% avg power). My 4iii initially read about 10% high, due to my L/R balance running 55/45 ish. The 4ii app lets you set the ratio by %, so it was just a matter of fiddling on a few trainer rides to get the 4iii so close that the noise doesn’t bother me. I would assume any of the one-sided PM apps woill allow you to alter the L/R %.
Unless your two powermeter’s readings are way different from each other (and cannot be corrected in the powermeter setup), does it really matter? If the two are a few percentage apart it is unlikely to be relevant to the big picture of your training …
Possible, in that everything that gets repeatedly hit will break eventually!
After three years, my pedals have had quite some abuse, but I am fairly conservative on my MTB - they are fairly scuffed up, though.
Adjusting FTP and load based on gear sounds very interesting. Has there been any development in this area? I ride both recumbent and upright bicycles, and it would be great to be able to account for different FTP on different bikes.
The ability to filter the power curve by gear is fantastic. I wish I could save my filters, though, so I don’t have to apply the same filter over and over again.
Currently you have to change the FTP for the activity manually. Now that gear can be automatically assigned with filters it might make sense to have gear based FTP in addition to the existing indoor and outdoor per sport settings.
