Upload workouts to Suunto watches
Hmm that does sound like a better way to do it. I will have a look see. Tx.
I have implemented this change. You can now always press the lap button to end the step. If a step has the “press lap” flag then it only ends when the lap button is pressed.
sorry @David but I have problem with suunto, I can’t see the planned workout on Guides. I have disconnect and then reconnected Intervals.icu to Suunto app but doesn’t work. Can you help me? thanks in advance
According to the logs your workout “recupero” for 2nd August has been uploaded to Suunto. Are you running the latest version of the Suunto app? I can’t think of any reason why it shouldn’t show up.
after uninstalling e reinstall the suunto app, always was fine. Thanks.
Could you pls share a screen of training view from any Suunto watches
where the target intensity range values (both of min and max) are visible ?
I am just curious, since I was not able to find such images on the “whole” internet.
If it looked like the Wahoos ‘Planned Workout Dial’ workout page
it would be great:
Thanks.
Hello!
When planning a workout with a first HR target step and then another pace target step, the watch does well in the HR step. However, in the pace target step it does not show all the fields.
It is a limitation of intervals or clocks.
Thank you.
That is an Intervals.icu limitation. The whole workout needs to be to the same target (power, hr or pace). You can create workouts that support several different targets for each step but the athlete needs choose one target and then all steps will use that.
I understand.
Thank you very much for your quick response.
Is there anyway to get the Target pace live feedback so you know if your ahead or behind in the interval, I have searched high and low and can’t find any specifics on this. I apologise if I’ve missed something in the threads.
