Upload of Workouts
Hi David,
Starting to use the future planner again, and one thing that would be really useful would be to have the ability to upload the .zwo (or other format I guess) to the workouts library so that the planned workouts can have the time in zone properly plotted in the activities weekly plan.
I would guess that you already have the mapping to go from the intervals markup to xml, so hopefully it’ll be a case of running it through in reverse? I’d assume that it could also calculate the estimated TSS and total time if it knows the intervals?
Thanks again for putting this together, it really has helped me structure this year’s training!
Thanks, Stuart
Tx. You can do that already (zwo, mrc and erg files supported). You need to add a new workout and then click “Import” at the bottom of the dialog:
Hi David,
Is it also possible to upload zwo files through the api.
Greetings
Theo
Yes you can (see “file_contents”):
