Just made a workout in XERT. I can upload from XERT to Strava, but as I use GC to load into interval, I would like XERT to upload to GC and from there to intervals. XERT don’t offer that opportunity.
Have anyone a solution?
Xert can upload to Strava. Intervals.icu then automatically syncs with Strava. Done.
Thx for the advice, but I’m using Garmin to upload to Intervals. If I also use Strava I’m get double and have to delete each time. Not ideal.
One possibility is to have a cykelcomputer to register the session, but also not ideal.
I hope to sort out the Strava dup issue soon.
Thx for that, David.
Can I Go back to Strava and only use that? Thought Strava was out.
Stay with it for a couple more days! I have almost figured out what the problem is.
Strava isn’t out but if you can use Garmin Connect you are probably better off. You can get L/R balance and other stuff + I can provide full API access to the data (not allowed with Strava) + you can decide what happens with your data. If Strava revoke my API access I have to delete everything on Intervals.icu that came from Strava.
Also Strava isn’t granting rate limit increases which puts a cap on the number of Strava users Intervals.icu can have.
Thx for reply.
