Update zones but not FTP
Hi all, not sure if I did something wrong, but I have updated my FTP-power as well as power zones in the settings. Then, I have tried to update the zones in both an individual training file
as well as in the activities overview
I always ended up with a change in the power zones but based on the old FTP-power used before.
It does not update to the new FTP. Do I miss something here??
many thanks
alfred
Updating zones means that you apply changes in zone settings for the selected activities. For example you changed Power zone 3 to 73-92% iso the default 75-95%. Or you changed your mind and want to use another set of HR zones or…
What you need to do in your case is change FTP historically. In List view, check all activities up until a certain date and choose edit and insert the FTP for that period. Then go on with the next period.
ok, thats tricky, but clear if you aware of it.
I assume however, that future rides will use the current FTP setting, right?
many thanks
alfred
They will use the most recent one
  • entered the same way
  • or set on an activity
  • or entered in settings
Add the column FTP in List view to clearly see what you have done. You can even edit directly on the list view, activity per activity, by clicking the FTP placeholder for each.
thanks for your assistance… :+1:
cheers
