Undo correction for heart rate artifacts
On two activities (Zwift races) I got a max heart rate that was above the setted max heart rate. Intervals.icu made a correction for it and lowered it because anything above the max heart rate is regarded as a artifact.
I’ve now set a new max heart rate. Is it possible to undo the correction? It seems that my max heart rate really is higher than I had seen earlier.
Did you click on the ‘Update activities’ button when you changed the HRmax in settings?
That will update all activities with new max HR and undo the clipping.
Thanks, that did the trick. I also had to click ‘re-analyse acitivity’ however. Only after that the graph was updated and the correction was removed.
