I was just playing around with the API to create/remove events (notes, holidays) that show up in the calendar and I noticed, that one color is named ‚margenta‘ with an R.
I think this might be a typo as I’ve never seen that spelling before.
Yes the id has a typo. It’s not super simple to fix. I need to find everywhere that uses the bad id and add code to fix. So have been ignoring for now.
I figured as much. I kinda just wanted to know how I should use this
I’ll probably end up doing some sort of struct/enum and rename them for my scripts internally.
That way I’ll only have to change this in one place, should you someday decide to fix it.
Well thats the other complication, I need to keep support for the misspelled version as well
probably at least for a while
