Trouble with Intervals.pro project
I apologize, it seems we are still encountering the same issue. My apologies for the persistent error.
Since your account appears authorized from my end, the problem might be more technical. In this case, I recommend reporting this specific error to the Intervals.icu support team. They might be able to diagnose why the system is failing to retrieve the athlete token despite showing as authorized.
The error message is: “Error sending test daily check: gather context: get athlete token: get token: no rows in result set.” You can provide them with this detail.
@Steve_Kala could you give a little bit more context?
where/whom is sending / asking to sent that detail?
2 posts were merged into an existing topic: Intervals Pro - AI Augmentation for Intervals!
That is an external project and unrelated to intervals.icu.
