Treadmill running pacing
Is there a way to fix the speed or pace of a TM run?
we know the garmin watch is not supper accurate and the speed on my TM run are sometimes way bellow what I did.
I know i can edit the overall distance, but I would also like to edit the interval distance…
For example… this AM i did 3x12 minutes 6:40, 6:35 and 6:27, The watch had at a 7:30ish pace (the last one was the slowest according to garmin). I would like to put the right pace on the intervals.
Confirming this. I regularly get crazy paces from treadmills (especially new treadmills models I haven’t run on before). Like Smashrun, it would be a very useful feature to at least be able to exclude from analytics. (My pace vs. time (all time) is completely messed up due to a handful of uncalibrated treadmill activities.
So, did you find a way to edit the pace values?
I have the same issue. Shouldnt be to hard to if you know that the intervals were all on same pace to set that pace to the lap
You can ignore the pace for a section or for the whole workout. I think it’s still difficult to adjust the pace for a section of the workout, because what then hapepns to the other section. And then the data would not correspond to the other data in the workout, such as HR and RR. I guess.
