Hi, I’ve read a few posts about syncing calendars from TP and can’t work out how to do this. Could someone please give me some instructions? Thanks.
Nathan
AFAIK the only way to ‘sync’ calendar is using the Options > Add Calendar functionality.
This will allow you to show a calendar that supports export in an .ics format - which I believe TP does, but only if you are a premium member…
If this works, I am not sure what type of data this will bring across. Based on my experience of pulling across a TrainerRoad calendar, this will probably be limited to something like workout name, planned duration and load only.
Thats about it unfortunately.
OK, thanks everyone
