Training builder - "," and "." in decimal numbers
Many users use a comma instead of a point in the decimal system. Can you make both possible?
I use an Excel tool to create my training. Here in Germany we use a comma instead of a period for numbers. I now have to change the system in Excel every time I create my training courses.
This should be a small obstacle for programming
Probably not…
There are lots of places in Intervals where you can export a csv. And that csv is in US format, meaning it uses a colon to separate fields. In Europe we use a semicolon when creating csv’s.
But you see that using the colon in numbers will possibly break most/all csv export.
You could create an Excell Template in US format and use that for creating your training. Then you don’t have to change the system all the time.
:smiley_cat:
Can you tell me how? I just found the solution in “Options” - but it is not template specific.
