Training Blocks
I guess most of us organise our training into periodised blocks?
Classically these are divided into Base and Build blocks and are commonly 3 weeks on with a recovery week, though can be 4 on with one recovery week.
However as we age we generally do not recover as well and many experts including Joe Friel recommend moving to a '2 on 1 off ’ schedule, even for the over forties.
It is however only recently that I have submitted to this ‘lesser’ regime now I am in my sixties, the problem being that my CTL (Fitness) progresses much slower.
So I have compromised and during the base phase (Base 1, 2 and 3) I still keep to a 3 on 1 off programme, but once moving into higher intensity work in the build phase then I tend to switch to 2 on 1 off.
This allows me to build a good CTL (fitness score) and then have more recovery when I need it most for the HIIT.
The ‘off’ week of course is not completely off the bike, I reduce the TSS to about 60% but otherwise continue to train.
I was wondering how other over 60’s organise their training and in particular if you use a 3 on 1 off, 2 on 1 off or any other such schedule.
I generally still use the 3-1 blocking, with the off week at about 60% of previous week’s TSS.
I typically do two interval sessions [one = over-unders and one = something like 30/15s] a week, one endurance ride [4 hours or more], two other endurance rides [length varying according to planned TSS] + 2 gym workouts [currently focussed on core strength]. Two days off per week [sometimes one, if a gym session is done on one of the off-cycling days]. I train for gran fondos and 1-3 week cycling tours. So, endurance events.
To be honest, I think that performance of the interval sessions commonly drops off in the third week, especially if TSS is high. But I embrace that, since the aim is to get to improving fatigue resistance for the longer tours. For the same reason, as I get nearer to a multi-day event, I stack workouts on 5 consecutive days in a week, then have two days off.
I must also say that, whatever the performance effects of having that week off, the psychological benefits are enormous!
So I think that 2/1 or 3/1 depends a lot on [a] your specific pattern of fatigue over the cycle and [b] your training goals. If I was training for events where interval training was more important, I’d be thinking of moving to a 2/1 ratio of work/recovery weeks.
Finally, I did experiment with “weeks” that were not 7 days long. However, such patterns of training really messed with my internal calendar [Mondays and Fridays off] and the ease of arranging other social obligations on the fly.
It’s a good point that it depends on your goal, I was always a road racer and so my build phase had a lot of VO2 Max work in it. Now I think I have probably done with racing and focusing on ride leading in Majorca, this of course is very endurance focused and can have some long climbs. I have to be fit enough to be able to lead the fast groups, so people in their 20’s and 30’s so still train like I am racing.
Fatigue resistance is something that is often over-looked but I think is something that can give you an edge. These days I don’t do much 5x5 VO2 work but tend to focus more on threshold with bursts, the bursts are in VO2 territory but not long enough to be true VO2 Max. I will ride to a long hill and do 4x15 threshold with bursts and then ride home and do some more threshold for that fatigue resistance.
I also do long Z2 rides at 70-75% and then throw some threshold in after 4 hours. It certainly works.
I have often considered a 9 or 10 day week, but like yourself I like to keep my internal calendar happy so have never actually given it a go.
Steve, any chance you could expand on what you refer to as Base 1, 2 & 3. e.g. what the focus, duration and/or purpose would be.
I’ve started a base that has increasing load and is around 8 weeks long. I missed a lot of training last year so I’m wondering what others would consider a strong base should contain especially if there were no immediate events on the horizon.
Jack, happy to go through it with you in more detail if you wish but here is an attempt at a quick explanation of how I do it.
The idea is as you say to have increasing load. If you have no events on the horizon so no date to work back from then continue to work your base and you can decide if and when to start the build phase a bit further down the line.
Typically a single training block would consist of 4 weeks, 3 weeks on and 1 week recovery but as we get older it is sometimes recommended to reduce that to 2 weeks on and one week recovery. I think this depends on each individual and you will know if 3 weeks on is too much. Often what I will do is do 3/1 during base and 2/1 during the HIIT work to follow in the build phase when you are specialising depending on chosen events/style of riding etc.
Also there is no reason why you can’t make a single block 2/1/2/1 and cover 6 weeks if time permits.
So, for me I generally have 3 base blocks and these could vary in length depending on how they need to fit in the calendar.
What the focus and duration needs to be is down to how much time you have, so you need to decide on how many hours a week you can commit to training.
Block 1 (Base 1)
So for block 1 (base 1) I personally focus almost exclusively on Zone 2 rides, zone 2 is a wide zone and I like to target the upper half of this so 65-75% FTP preferably 70%+ and I just ride loads of hours so a typical week would be.
Mon-Day off, Tue-2 hours @ 75%, Wed-3 hrs @ 70%, Thu-2hrs 70-75%, Fri- 1 hour recovery or day off, Sat 2 hrs @ 75%, Sun 3-4 hrs 65-75%
I don’t worry if I stray into Zone 3 a little on climbs and I try to ride with constant pressure on the pedals (no coasting) so pick a flatish route and try and keep pedaling on the downhills if you can.
The 4th week in the block is the recovery week, this means continue to train but reduce the TSS to about 60% of the previous weeks.
Now if you are a proponent of pure polarised training you will not do what I do in blocks 2 and 3 which is introduce Tempo and Sweetspot training, however I believe there is good reason to train these zones during base, after all unless we are racing criteriums then there is a good chance we are going to be riding quite a lot in these areas and if we are doing any event that require long climbs of 20 mins or more then we will be riding sweetspot quite a lot.
Sweetspot can be quite uncomfortable and I think it is good to get the body (and the mind) used to riding for long intervals at this pace.
However, I only do this during base 2 and 3, it is very efficient at raising your ftp but your fitness can plateau and so you need to move onwards and upwards. I only ride Sweetspot for a couple or three weeks at most. Once I go into the build phase then I tend to ditch it altogether and train to more of a polarised model.
Block2 (Base 2)
In block 2 I start to introduce Tempo riding, so twice a week I will work on tempo, depending on current fitness perhaps start with 3 x 10 Tempo riding at the middle to high end of the zone at around 83% ftp, keep it steady, if out on the road pick a spot where there are no downhill sections, traffic lights etc, gentle uphill can help.
Once you can do 3x10 then do 4x10, then 3x15 etc and build to 3 or 4x20 mins tempo.
Then start on tempo with bursts, so maybe start with 2 or 3x20 tempo riding at the lower end of your zone 3 and every 2 mins do an out of the saddle burst to 120% ftp. These are training you to go with any surges in races or events, build to doing 3x20 tempo with surges or 4x20 if you can.
Block 3 (Base 3)
Now we up it some more and start to introduce Sweetspot and then Sweetspot bursts.
Start at 3 or 4x10 mins at 90% ftp and build until you can do 3 x 20 at 90%. That’s an hour at sweetspot which is going to give your ftp a great burst.
Then start on sweetspot with bursts, so ride at lower sweetspot (top of zone 3 flirting with zone 4) and every 2 mins an out of the saddle burts for 10 secs, so 1:50 SS and 0:10 120%.
If you still have no real target then you can extend these blocks somewhat and perhaps put another block in doing some Over-unders, criss cross, stair steps etc (check my workouts for those in the group page).
Don’t forget whilst you are doing these tempo sweetspot workouts you need to stick to Z2 for the rest of your rides, so do perhaps 2 sweetspot workouts a week and the rest should be Z2 or recovery rides, don’t be tempted to go harder during these or you will not be recovered for the harder days.
So a typical block 3 week for me would be
Mon: Day off, Tue: Sweetspot Wed: 3 hrs Z2, Thu: 2 hours Z2 Fri: Sweetspot Sat: 3 hrs Z2, Sun: 4 hrs Z2
Build phase
During the build phase is where you specialise for your event so no details here yet but I would typically do a block of Threshold work, so build until you can ride 4x15 at 100% then start doing threshold bursts which are 1:50 at 95-100% then 10secs at 150% and build to 3x15 of these.
They are very hard but really work. Don’t do more than 2 of these workouts a week and keep the rest at Z2 or lower, this is where I may start doing 2/1 weeks as mentioned above.
In Block 2 I may start doing VO2 max work but if I am not racing I may just keep with the threshold work.
Sorry that was a long post in the end and I have no idea if that answers your question but please feel free to ask away, others may have different ideas or disagree with what I have said but it works for me.
Thanks for taking the time to post that @Steve_Tucker. Do you have any benchmarks that you aim to achieve at the end of each block. Say a specific increase in fitness points or extra watts on FTP? Is there any mileage in testing HR decoupling as an indication that it’s safe to move on?
Alan H you are welcome to look at my fitness chart, you will see where I am now and where I was last October which is where I would like to to be by the end of the build phase (though it may take a bit longer due to a recent knee issue. I don’t have a specific number I need to be at by the end of base 3 but try and keep my CTL climbing to that end and try and keep it steep enough to get where I want when I want, but it’s not an exact science.
I do think HR decoupling is a great way to decide when to move on, I do this myself to a point at least.
@Steve_Tucker … thanks. Could you enumerate on what you would include in Build, even expanding on what you’ve said. I like the way you break base into 1,2 or 3 phases. Would build be the same?
@Jack_Zlm
This is the way I do my build phase, it works for me. I am not saying it is right for anyone else.
The Build Phase
The build phase is where you specialise for the type of event(s) you intend to be riding, whether that be long road races, time trials, criteriums, Gran Fondos etc., fast group rides or a mixture of more than one. Assuming you have a good base then the work you do now will build on that to bring you to a peak for your target event(s).
The timing of your build phase is critical if you wish to peak for a certain event and so when you put a training schedule together you should work back from your event. If the timing is wrong then you can always extend the base period to stretch it out.
Also remember if you start HIIT too soon then you risk peaking too early and your fitness will plateau with nowhere to go but down.
Maybe you don’t have a specific event and just want to be a strong rider in general. For me this year I am unsure if I will race but need to be fit to be able to ride with younger fit riders as I will be leading rides for a couple of companies. The rides are long and often have long climbs where it often gets competitive and so I am aiming to have a good FTP and already have a very good base so I can cope with day after day of long hard rides.
My base generally is on a 3 weeks on 1 week recovery basis, but as the intensity builds then I have started to look at doing 2 on 1 recovery for the build phase. Also I am a bit short on time before I fly out so have had to squeeze my build period a bit but will continue to work on it once working as ride leader.
Build 1
This is where I focus on threshold work and will directly improve your FTP. The intervals are done right at FTP 100-105%. They will build fatigue and you will need to recover well between workouts. I like to leave at least 2 easier days between workouts so typically would do these on a Tuesday and Friday.
There are many threshold workouts you can do, over-unders, stair steps, ramp intervals etc etc.
What I like to do though is build to doing a total of at least 60 mins at FTP in a workout. So I may start with 4x10 (4x8 if thats too much) then 3x15, 4x15.
I like to find a steady climb of at least 15 mins for these (the emphasis on steady probably <5 or 6%) with no downhill. If you don’t have a long hill do it on the flat into the wind, but no downhill, traffic lights etc.
I like to do these outdoors though they can be done on the trainer, after the workout I like to add some solid endurance on the ride home, perhaps with a few efforts to give fatigue resistance which does wonders for being able to find that bit extra towards the end of a long event.
You also should keep working on endurance but make sure you stick to zone 2 (or Z1 if a recovery ride). So typically I will do a mid-long ride on a wednesday and perhaps a 2 hour ride on saturday (or recovery if I feel really fatigued) and then a long ride of 4-5 plus hours on a sunday. Sometimes this is a club ride but you need to be careful not to work too hard on these.
This is what a week might look like in my Build 1
Recovery Weeks
I don’t call them a rest week, that implies a week off which is not the case, I try to lower the volume but maintain some intensity whilst keeping the TSS to about 60% of the block, especially if doing a 2/1 block where your CTL (fitness score could drop too much).
Build 2
For build 2 I up the intensity some more whilst still working mainly in threshold and endurance. So for this I start adding bursts to my threshold intervals. These will help with the ability to go with the surges that usually happen on long climbs, or to make others suffer. They will really raise your FTP.
So, once you can do 4x15 at threshold it is time to introduce the surges, so go for 3x15 or 2x15 if that is too hard and work up to 3x15 or even 4x15 may be possible though I find 3 is enough as I often add fatigue resistance work on the way home.
On a 15 minute steady climb ride at a slightly lower 91-100% and every 1 minute 50 seconds do a burst to 130-150%, I tend to start the burst out of the saddle to wind it up and then finish it sat down.
A typical week
HIIT
Of course FTP is not the be all and end all. You will notice that I have not included any VO2 Max work or above in my build 1 or 2. If I am targeting racing (Masters road racing for me) then I would be including at least one VO2 workout a week, in actual fact what I would do is add a 3rd build block especially as I am only doing 2/1 and would specialise on VO2 Max work for the final block before racing. If I were riding crits I would do some specific training for that. For the likes of my plans for this year I’m not sure I need to do any specific VO2 intervals but will get some in on an ad-hoc basis, the same would apply for me if I were doing Gran Fondo’s or long non racing events where the ability to go long and probably includes long climbs.
If you are programming for a specific event don’t forget to allow for a taper week.
Thanks Steve for posting your workouts and taking the time explaining your training approach. I just built-in the 2/3x20 sweet spot with bursts workouts into my sweet spot block. Tough cookies! I might give the thresholds a try at the end of February!
Yes they are tough workouts, on the first 20 it seems quite easy to begin with but by 10 mins I’m thinking I’ll never do another 2 but once I get into the second 20 it gets easier mentally knowing there is only one more. The trick is after each burst drop to your sweetspot power but no lower.
Enjoy!!
Thank you Steve for posting these two training templates. Together with your library, they represent a great resource for aspiring oldies. Wonderful.
I tend to keep some higher intensity work going all year round. Partly this is because of the warning about losing higher end power as one gets older; partly because I have weak short duration power; partly because I have “events” through the year [eg, gran fondos in Australia in spring / autumn + tours in China or Europe in winter].
But like you, I reserve sweet spot for build / specific preparation. No races, so sweet spot in specific preparation. But those sweet spot / threshold workouts with bursts look like something else altogether. Maybe I’ll have to try them. Maybe.
But thanks a lot for all this.
Thanks @Steve_Tucker you have laid it out nicely. I particularly like your focus on the output of the workouts, i.e. time at FTP and working towards 60min!
I seem to be hearing a lot lately that we should increase the duration before we increase power, Cheers.
Yes maintaining higher intensity work Zone 5 and above is generally recommended as you say, else we lose it as we age. I don’t actually do specific HIIT workouts in winter but often get up there during group rides and other road rides naturally, whether I do enough is the question.
Let me know what you think of the burst if you try them.
Thanks @Steve_Tucker Great info! Much of this is new to me…I’m learning a lot! Thanks for the workout libraries as well!
Thank you Elaine, I don’t claim to be an expert but feel free to ask if you have any questions with regards the above.
I a little curious about best recovery week strategy, beyond cutting TSS 50-60%. TrainerRoad seems to cut all intensity and only has prescribed Z2. In my logical mind, it the better strategy would be to keep the intensity but loose the volume. Thoughts?
If you watch these 2 videos, the first does mention recovery weeks towards the end and the second seems to be about a taper week, but they both state that volume and intensity should be about half, Phil Gaimon says its the only time he has two days off the bike in a row and I have done this and it seems about right for me, he also says cut the intensity in half, so if doing 10 sprints only do 5 on that day in the week, or I guess any other intervals you normally do.
I guess it also depends if you are on a 3/1 programme or a 2/1 as to how much recovery you need.
Thank you Steve, That reinforces what I feel to be the correct approach but with better information. I will take a look at these tomorrow.
Agreed, @Steve_Tucker – Gaimon’s advice is what I do: half the number of intervals, 50-60% of the time.
