Hi - new user here. Absolutely loving the app so far! I feel like I’m missing a simple answer, but can’t figure this out or find instructions. How do I import my TR calendar?
Thanks David. When you do that, it says “ Enter a URL or link to a calendar in iCalendar (.ics) format”
How do I get my TR calendar into .ics format?
The TR export is in .ics format. You just need to follow the “manual setup” instructions below to get the URL and enter that in Intervals.icu:
https://support.trainerroad.com/hc/en-us/articles/360022469251-Calendar-Export
Hi David, are you saying I first have to sync TrainerRoad to some other calendar (outlook, google) and then sync that calendar to intervals.icu?
No not at all. You can use the same link you would manually load into Google or Outlook with Intervals.icu. I was just explaining how to get the link from TR.
Sorry. I don’t understand.
Ok Intervals.icu falls into this category from the TR page:
Don’t see your service listed?
No problem! As long as your service supports subscribing to a Calendar URL you can still sync your TrainerRoad Calendar.
You need to do this part: Copy Calendar URL from TrainerRoad
and then click “Add Calendar” in Intervals.icu and paste it into the URL box on the form:
Drat. I am not currently a TR subscriber so I can’t go poke around and find it. Maybe someone here could help or perhaps ask on the TR forums?
Ok. Thanks for trying.
Posting to help others. Once you get to the screen above, click on “Google” and then expand the “Instructions” to get access to the calendar link.
Thanks to Chad for his help!
You can choose whatever you want there, next step you choose show instructions. There you will find your TR calender link. Just copy that into intervals
Kudos to you @david for this webpage, brilliant job!.
I just wanted to ask if it is possible import the details of the workout? The intensity and load are imported but not the specific intervals:
Tx. Unfortunately that information is not available in the calendar export from TR.
Do you know if this is ever going to be possible? Assume TR would not put this info on their API, as they probably want people using their Calendar. Looks like Trainerday API has workout details vs time, but they understandably don’t have the whole TR catalog
https://trainerday.com/api/
Probably not. That would make it very easy for people to create all the TR workouts in Intervals.icu, copy the plans and so on.
Work with TrainerRoad. And BigRingVR. Just saying (again)
There was bit of a hassle between TR and TD, but they sorted that out and are on friendly terms.
I have been chatting with TD. Tx for kicking this off on Twitter
Need to sort out this Strava business first though.
