Hello everyone.
Is it intended that the 7-zone model is always used under totals, no matter which model I use for my own calculation?
It was coded initially like that and it is difficult to change now.
So which zone-model and which zones are used for the totals?
It should only use the zones that you defined. Normally the Z4 time in your case should be 0…
Are all activities in that range defined to use your three zone system?
Time in Zone settings are stored per activity individually, so at first sight I would think that you have activities in that date range who still have an older HR zone setting.
Thx, I just wanted to understand the zone-model in totals. Now I know how it works.
