Not sure if I’m doing something wrong with some configuration but numbers on Total and the equivalent gear don’t match.
Tks
Some things to check:
Totals shows 78 activities, and your gear 50, so the difference would come from one of the scenarios.
Hi Gerald, tks in advance.
Yes.
Default.
One shoe.
Regards,
Pls: picture on the first post shows most of my config but shows. Only one.
Hi @david, pls, any word on that?
I did a double check and it appears configs are ok.
There are only Run, Trail Run and Virtual Run ( Treadmill on Garmin) as “RUN” and “RUN” has only one shoe as default.
So no idea why numbers don’t match.
Tks
It sounds like you maybe misinterpreted a question. Do all 78 activities have the gear assigned? You can check them all quickly with the list view.
Hi @david
For some reason I can not fix gear for the 4 activities bellow either on Intervals nor Strava.
Could you please take a look ?
Thank you,
For some reason Strava won’t accept gear updates for those activities. They have the “Trainer” flag set and most (but not all) of the others do not. I think you should log a ticket with Strava since you can’t change the gear in the Strava UI either.
