Toggle Sessions actually completed vs planned
Not sure if this can be done already but it would be really cool if you could toggle the calendar view between completed and planned sessions.
I know you can show planned and completed, or just completed, but it would be nice just to see what you had planned for a block without seeing what you actually did.
Keep up the great work. :slight_smile:
actually, how does Intervals know if a planned activity has been completed? I often see duplicate activities, so I tend to just remove the planned ones tbh.
Tx, I have added that to the todo list.
@Andre_Lemos Intervals.icu looks at the total training load planned for the day vs what was actually done, by activity type (Ride, Run etc.). If the day is “today” then it shows both planned and completed. If the day is in the past then it only shows completed activities unless you have checked the “show past planned workouts” box in “Options” on the calendar. You can also tick “Show compliance to plan” to see how closely your actual work matched the plan.
is there some leeway on the load? Like if it’s +/- 5% or something?
the reason I’m asking, is because I don’t think I’ve ever saw the feature working, but I will keep my eye out!
nevermind, I think I get it now. It will just show the percentage of the completion Vs. the planned load.
Yes, it does.
I like it, but sometime want to just see the original plan without the noise of what I did, for example to assess if I should apply it again, toggle from planned to completed to decide if it was a good idea or more or less than I could tolerate.
