Hello! I would like to suggest that the date and history of the data entered could be included in the Threshold Power/Heart Rate/Pace settings. Is this possible?
Currently, retroactively adjusting thresholds for past dates is a bit tedious—it involves filtering a date range, selecting activities, and adjusting via “edit.”
I’ve seen an interesting workflow where you simply select a specific date, enter the threshold value (e.g., FTP), and all workouts after that date (but only up until the next manually entered value) are automatically assigned that threshold. This dramatically improves threshold history management, especially when dealing with large imports of old activity files spanning long periods.
As a bonus, a small optional omment field would be great along every value, allowing notes like “FTP set via CP test,” “Suggested by Garmin or Intervals after a fast group ride,” or “Suggested by Intervals as new eFTP” to track how and why each change was made.
This works here to in the following case:
- FTP value is empty for ones you want to modify. An existing value will not be overridden
- You must re-analyse the ones that were modified to take the new value in account
It sounds easier, for the moment. Will try that. Thanks @MedTechCD !
