Temperature setting?
Is there a way to set temperature to Fahrenheit? Celsius doesn’t mean much to most Americans. Sorry if I’m overlooking an obvious setting.
Separately, every time I go to Intervals.icu on my iPhone in Safari, it immediately gives me a green header banner saying “A new version of Intervals.icu is available. Click OK to reload the page with the new version.” It was also doing it on the desktop site for awhile, but seems to have stopped.
There isn’t a Fahrenheit setting but I can add one. Probably best to keep it separate from the existing “Miles & Pounds” option as I suspect some people in the UK use miles and degrees C. It’s now on the todo list.
The new version box comes up whenever I make changes to the UI which is often several times a day. It’s a courtesy to not just reload the app while you are using it. But I need a new plan since it bugs a lot of people.
I’ll second this! Not a huge deal but it would be nice to have as 30C means less to me than 86F
Ok. I finally got this done. Will deploy Friday AM (GMT+2).
@david I just noticed that the temperature units on a fitness chart graph (min/max/avg temp) are always celsius, regardless of the user settings. Possibly user error but I couldn’t find a way to force fahrenheit.
Mine appears to be showing 32 degrees F on every interval of every activity.
