Hello, No matter how many times I refresh, try different browsers, logout/login, I can’t seem to get it to sync strava data from may/june/early july. Clicking the circular arrow also doesn’t seem to do it.
Any ideas? Does it only pull in the most recent rides?
strava has a limit on how many API calls can/allowed to be made in a day. So if it’s over the limit, you will need to be queued for later.
however, for your issue, IIRC (from forum - you can do a search) what you can do is to zoom in (select those ranges) in the fitnes/fatigue chart and then click on Sync.
IIRC that is what the post on the forum says and that’s also what I did.
intervals will stop syncin if user hasn’t been on the site for x weeks. or soemthig like that
They way data is fetched from Strava can create gaps. The refresh button on the /fitness page will try fix those gaps. I just did that for you and those activities are loading in. I can’t do this automatically because it uses too many Strava API requests and they have tough limits.
