Hi, super newb question… I have all of my activities (including strength sessions which Is what I really want to get imported) in TrainingPeaks, but not Garmin connect or Strava (those have just rides). In order to get my current strength workouts imported here, I suppose I can figure out how to export just those and then import, but how do I import files “over” what is getting imported from Strava? Does that make sense?.
(i’m assuming we can’t use TrainingPeaks to import from, correct? I have to keep that as I have a lot of athletes in there also, but trying to change myself over to Intervals first, and then bring others along)
Would it make sense for me to change to importing from Garmin Connect for future imports and make sure that strength sessions get in there so it all happens perfectly? If I select that option though, will it double import everything, over the activities that are already there?
For past activities you can export all activities form TP to a file and upload and extract to a dropbox folder (just create an account there). Intervals will download from dropbox and add missing data and activities and merge existing ones. For future i would use garmin if you use their device. But remembar garmin has limited sync capabilities.
ah dang. so the strength get into TP because that’s where i schedule them; similar to the rides. so i manually check them off. i guess i just need to do that here also, manually do it for future
