Switch notes to top of screen instead of bottom
Notes from the calendar appear at the bottom of the screen on the Fitness menu e.g.
Based on the setting of the note in the calendar entry e.g.
It would be good to have these flipped to appear at the top of the screen given the dots or entries are shown on the Fitness chart that is also at the top of the screen.
Mine is shown on the top
but from the looks of it, seems like it’s different “look”
I like your look better, how did you manage to make it look like that?
nothing unusual, it’s the default look.
Depending on the date range, it can get a bit cluttered.
On my setup I like to have the dots on the fitness line, then the label shows at the bottom of the screen when you mouse over the dots. My request is just to move the “mouse over” label to the top of the screen instead.
As many have said, yes I could have the label inside the fitness chart, which is the default look (but can get cluttered, hence prefer the dots+mouseover).
