Swimming: Different lap time/paces between intervals.icu and Garmin
I’m new to both this site (it’s incredible!) and my Garmin. I have been using my Garmin while swimming and manually pressing the lap button between my swims (100s, 200s, etc.). I noticed that the lap times and paces are 1-4 seconds slower on intervals.icu than they are on my Garmin. I’m not sure which is “correct” and what is causing the discrepancy. If it’s relevant, I do flip turns during my swims, and I have connected intervals.icu to both my Garmin Connect and Strava data.
I have seen older posts here from people experiencing the same discrepancy, but I can’t tell if a concrete explanation or solution was ever given. Here are some examples of 2x 100yards and 1x 200yards (intevals.icu is the first pic, Garmin Connect are the 2nd and 3rd pic).
At the end of the day, it’s not a huge issue–I set my intervals.icu pace zones based on my intervals.icu paces, so even if everything is slower than reality, it’s at least consistent.
Thanks in advance for any response, and thank you for this incredible site! I adore it!
i’m thinking.. this could be due to Heuristic lap detection.
is your “use laps” on for the activity? (so intervals.icu wil use Garmin’s LAP data in the FIT file)
Yes, “use laps” is on by default for me
Looking at some of my workouts, it appears the issue is that Garmin swim fit files contains two ways to determine the time of a lap:
total_elapsed_time : this is what is shown in connect
timestamp - start_time : this is the value that intervals shows
I believe the difference is due to watches automatically determining when you finish a length. Since it can take a second or two for the watch to say “yes, a length was finished”, it sets the elapsed to when it thinks that length finished, but writes the timestamp those few seconds later so there ends up being a discrepancy.
@david is it possible to switch to using total_elapsed_time or total_timer_time if it isn’t already?
IIRC, when I was develping my app to cater and process SWIM FIT files, I found that the timestamp parameter (basically end time) is actually all either Fake / static / dummy and IS NOT a requirement in the FIT standard.
This is from a Garmin 255 IIRC (length messages)
Browsing the forums to find an answer to my question, I’m having the same issue. Would be great to get this fixed/solved as it’s changing the precision of the data in Intervals.Icu. While a second here or there might not matter for running or cycling, for swimming it’s a big deal. See screenshots below of Intervals.Icu data vs Garmin data:
Intervals.Icu staff, can we please fix/solve this? Thank you!
Not perfect, but there are several activity charts for better visuality using the fit file data
For swimming this might be of interest:
Or here an example to show the lap data in a table (so the same values like Garmin or… whatever shows)
