Hello David,
I was looking for a functionality that Golden Cheetah already has an I’ve not been able to find it in intervals.icu.
It is so obvious that maybe it’s my fault to find it. In that case, sorry for asking!
What I was trying to is to select a subsport or cycling discipline for each activity, so then you can filter power curve, ftp and other statistics by that subsport.
The same you can do with indoor/outdoor ftp, but splitting into road & mtb the outdoor (or even gravel, CX, etc.).
I saw you can filter by powermeter, and this would be a workaround, but if you switch to a new power meter, you would loose the previous one data. Or if you use the same powermeter for two disciplines you will mix data.
Does it make any sense to add that field?
