When using stryd in running, the comparative histograms with other Intervals users are not displayed?
Those tables are currently only generated for rides. I will see if there is enough data to add running.
With any luck the ranking tables and histograms will work for running and rowing later this week.
Ranking tables for running and rowing are live now. Will do an announcement on Thurs. I also fixed a bug that was causing the cycling tables to not be updated. So the sample sizes are now much bigger.
Thank you David, you are the best hehehe
