Strava Zip file is not uploading
I just signed up and I am having a problem uploading my strava date. It never completes. I have tried it in Safari and Chrome. What am I doing wrong?
I thought you have to be supporter to import Strava history, but not sure.
In any case you don’t have to upload the zip file you shall enter the download link, the backend handles the download of the zip file.
Are you referring to the actual zip file, or as @R2Tom mentions a link to the file?
If you have the zip file, then unzip the folder and upload the files, in smaller batches.
Do I upload the individual fit files? How do I do that.
If you want to use the “import all strava data” function, you have to enter the URL link to the zip file (right click on the link > copy address)
If you have downloaded the archive, you should have received an email similar to this.
It will be a zip file, that you can then unzip.
Once unzipped, you drag and drop the files (try 10-20 at a time) using the upload function.
Loading the zip file, if too large, might cause your problems.
Using this option, will result in duplicates if you have previously had a file linked. (It will show upload as the source). This is why using the download link that @R2Tom mentions is a better option.
Thanks for the response Tom, here’s what I see when requesting the data from Strava.
So I pulled that file down, stuck it in dropbox so I could then pull a link to feed in here:
I see - you’re pulling the link from the email - my bad.
