Strava connection lost
What to do?
My all activities is lost and there’s view on strava button lost also.
If we revoke access to Strava automatically all activities are eliminated, the solution is to turn off sync without revoking access, unless it is some other failure
You need to re-connect with Strava and they will come back. Unfortunately the Strava API terms of service requires Intervals.icu to delete everything from Strava if you revoke access. This happens after a day or so to allow recovery from accidents.
Hi.
If I revoke my Strava, for a month, can I will lost my data on intervals, or on my Strava?
You will lose your data on Intervals.icu. Rather just untick the “Download activities” box in Strava in /settings.
Thank you, I will try it.
So in Strava my data remain safe?
How can I backup my data from Strava, because only 3 month data can be download to Intervals
I unticked “Download activities” box in fittarpi@gmail.com profil.
I tried to connect with Strava in szoarp@gmail.com profil, and received these:
status 422
error Strava athlete is already linked to a different Intervals.icu account, try ‘Connect with Strava’ on the login page
Si I need to revoke Strava in fittarpi? If I do so, later, I will not be able to connect again?
Yes you need to disconnect one of your profiles and then immediately connect the other.
Yes login to strava with fittarp@gmail.com and I REVOKE inervals.icu and after I login to strava with szoarp@gmail.com I clicked the Connect, but not work. The same error “Strava athlete is already linked to a different Intervals.icu account, try ‘Connect with Strava’ on the login page”.
What did I do wrong?
Can you please send me your Strava ID. I will manually unlink it from Intervals.icu and then you should be able to connect.
My Strava registered with szoarp@gmail.com
Strava ID 96796443
I have just disconnected you. Now login with the correct Intervals.icu account and link Strava.
Thank you it is work, It is OK now.
Thank you very much
