Completed a sprint workout today and noticed the sprints were adjusted due to being 30% over FTP (they were treate as power spikes). I did look at raw data and saw the sprints. Noticed my load (TSS) was adjusted to reflect the “spikes” and was much lower then what Garmin and TP had computed. I was able to edit load but Intensity was also lower then actual and I was not able to adjust that?? I understand the reasoning behind spikes, but it seems to corrupt a sprint workout… Also Intervals. ICU under estimated my Max 1 second power (Pmax). Thoughts??
You should probably just bump up the spike threshold in /settings so your sprints do not get clipped. The intensity number is normalised power / FTP and that isn’t editable for activities with power. But if you get rid of the clipping by adjusting the spike detection the numbers should match Garmin and TP.
I changed the spike threshold to 90% for that ride to get rid of the clipping.
OK, thanks… I didn’t know that was a setting!!
