Not sure what is happening, and whether it’s a bug or an issue with my setup as I’ve been tinkering around a bit. But, I’ve noticed that my power curves for previous seasons aren’t showing up on the power tab, BUT they are showing when I analyze the power for a given activity.
Is it possible that I’ve inadvertently clicked something to change the visibility here?
Tick one of the boxes:
all activities, or
indoor/outdoor
Thanks for the quick reply Gerald, I’ve tried that, but still have the same result.
Top left, you only have July showing.
Change the date range to wider dates.
That doesn’t seem to do it either. In fact, that’s a bit confusing. Choosing 2024 for instance will then change that value to Jan 2024. Checking 2023 will take me to August 2023. Then when I click on 2025, it takes me to August of 2025. I can’t seem to figure the rhyme or reason to what those values to being set by.
Regardless, changing that value didn’t show any additional curves.
Mine works fine.
Just trying to see what you have showing vs mine.
Your best efforts are the same across all durations for a few periods. See the power on the right. All time outdoor, and 2023 are the same.
I think I know what happened !!
Most of my power data is coming from Virtual Rides (Zwift & Peloton). I had added Virtual Rides as a different Sport under my Settings which removed the Virtual Ride activity type from my Ride Sport settings. I then deleted the Virtual Rides (Sport) from my settings, but didn’t add that activity type back into the included Activity Types for my Ride (sport). If I add Virtual Rides activities back in, I have all the power curves included again.
((Sorry, all that nomenclature is a bit confusing))
And yes, the efforts are the same because there is only a single Outdoor ride that has power data. That ride was in 2023 so that is why it was showing up for both 2023 and All-Time.
I think I understand what is/was happening. Thanks so much Gerald for helping out here. Much appreciated!
No problem; helps to understand the process as there could be multiple factors affecting it.
