Hi!
For some reason my girlfriends zwift workout laps does not align correctly with data. Any ideas? Laps are in place in strava.
-Aleksi
Hi!
-Aleksi
Probably because of pauses. You can align them by clicking options at the bottom of the activity page and adjusting the slider.
There are a few options for how the lap detection is run. If you go to actions-analyze it will give you some options for how it should try and find them.
If none of the options end up how you expect, you may have to manually edit the intervals.
These are true laps from the workout. Not detected by intervals. There are no pauses. Its always off about 30s.
Im using exactly same setup without any issues. Strangest thing here is that those laps are in place in the file.
Can you align using the slider?
If it comes in through Strava, check the Privacy Circle. It is known as a problem for workouts with GPS, but since this is Zwift, I don’t know. Doesn’t hurt to check though.
Thanks! It was probably that. Privacy circle says " no matter where they happen". Better just use address based one for her.
