[SOLVED] Issues with garmin
I have tried to synchronize with Garmin connect.
Planned workouts are syncing from Intervals and are vissible on my watch.
The data just doesnt get from garmin to intervals.
I have tried to re-authenticate.
I can see the calls to fetch older activities going through to Garmin in the logs without errors but no activities are coming back. Actually as I was writing this they started appearing on your calendar! So it looks like things were just delayed.
If you want all your Garmin data use the “Import All Garmin Data” button.
Hi David
Thank you for the reply.
Mads is one of the runners i coach.
We tried to unpair and pair a couple of times which in the end did the trick :muscle:
