[SOLVED - IMPLEMENTED] Re-upload and re-analyze multiple Strava activities
Hi - I did a Strava sync this morning for all my history and many of the files don’t have all the data populated. If I go into an individual file I can re-sync and re-analyze the file and the data will populate and everything is calculated. Is there a way to do this for multiple selected activities in the Activity List View? Basically would like to select every activity where there is no Intensity value (see pic)
this doesn’t work?
Doesn’t work for me…I have to go into the activity (which is basically blank, no chart, etc) and Reload From Strava in the Actions menu, then Re-Analyze.
maybe it’s still populating from Strava? since you mentioned “entire” history?
BTW, for non-supporters, I’m not exactly sure how many months you can get Strava Sync to go back towards? 3 months?
if you have garmin, better to request the full history from garmin instead
If zones, FTP and LTHR are not yet set on the settings page, you may get get empty charts too.
Thanks for the replies. Unfortunately I don’t think we’ve hit on the problem. It’s not a huge deal, I’ve re-synced a lot of the history individually, but not all of it.
But just to keep this documented: I was previously not a “supporter”, in which case I had the 3 months of Strava synced (or whatever the limit is). Then I became a supporter and chose a manual date range to sync the rest of my Strava history. Most of the files synced properly, some did not, there doesn’t seem to be a pattern to it. I definitely had my settings (FTP, LTHR) set. It’s not a still populating issue as it’s been a few days now. Guessing just a one-time batch upload/syncing issue. If you had a way to re-sync and re-analyze from the List View for multiple selected activities, I think that would be a solution.
Thanks. “Re-process file” on the activity list view now reloads Strava activities from Strava. So you can use it on Strava and non-Strava stuff. Will deploy Tues AM (GMT+2).
Just tested this - works great! Thank you
I stumbled upon the same issue. This action does not include the manually added data (notes, photographs) though. Am I right?
i would believe you’re right as these are metadata “linked” to the activity via the respective companies’ own database and is not directly in the FIT file.
Some of my activities on Intervals contain notes and photos synced from Strava, apparently not always. It kind of makes me wonder how much time I have after an activity is uploaded to Strava to add notes and photosGEAR, before they are synced to Intervals.
I never saw photos synced from Strava. Is this even possible?
I agree w/ @R2Tom… Notes (as in desc) & Titles are synced (doesn’t matter when you edit it, a change in Strava will trigger Intervals.icu to update the title/desc)
The photos, SHOULD NOT be sync’ed. Didn’t see any anouncement about this being available and My own BreakAway : Indoor Training app also i don’t see a way to upload / pull the photo. (or thing has changed… )
I apologise for the confusion! :face_with_peeking_eye: I meant gear. (previous post edited)
